OnCommand Workflow Automation 安装在使用长密码时挂起
适用于
- OnCommand Workflow Automation ( WFA ) 5.1
- Windows Server 2016 和其他支持的版本
问题
- 当安装向导提示您输入 WFA 服务器服务登录帐户时,您提供的密码超过 14 个字符
- 在填写完要开始安装的继续信息后、它会挂起、并且不会在以下屏幕上继续
- 安装挂起时、打开 Windows 文件资源管理器并键入
%temp%
地址栏字段并按 Enter 键以打开当前用户的临时目录 - 找到与当前 WFA 安装关联的 mSixxx.log 文件
- 滚动到日志文件的底部并确认在下一节中未进行任何更新
InstallShield 10:24:19: Invoking script function wfaServerService
Custom Install Log INFORMATION:
MySQL Exe path : C:\Program Files\MySQL\bin
MySQL Home : C:\Program Files\MySQL
Executable path for creating symlinks : cmd.exe
The value of Program and Params for creating link cmd=cmd.exe /c mklink /D "E:\NetApp\WFA\jboss\standalone\deployments\log.war""E:\NetApp\WFA\jboss\standalone\log.war"
Successfully Created link using cmd=cmd.exe /c mklink /D "E:\NetApp\WFA\jboss\standalone\deployments\log.war""E:\NetApp\WFA\jboss\standalone\log.war"
Custom Install Log ERROR:
Successfully created dir=E:\NetApp\WFA\jboss\standalone\log.war\jboss
The value of Program and Params for creating linkcmd.exe /c mklink /D "E:\NetApp\WFA\jboss\standalone\log""E:\NetApp\WFA\jboss\standalone\log.war\jboss"
Successfully created link using cmd = cmd.exe /c mklink /D "E:\NetApp\WFA\jboss\standalone\log""E:\NetApp\WFA\jboss\standalone\log.war\jboss"
The value of Program and Params for creating link /c mklink /D "E:\NetApp\WFA\jboss\standalone\deployments\help.war""E:\NetApp\WFA\jboss\standalone\help.war"
Successfully executed : cmd.exe /c mklink /D "E:\NetApp\WFA\jboss\standalone\deployments\help.war""E:\NetApp\WFA\jboss\standalone\help.war"
The command line for making link:cmd.exe /c mklink /D "E:\NetApp\WFA\jboss\standalone\workflow-help""E:\NetApp\WFA\jboss\standalone\help.war\workflow"
Successfully created a link. cmd.exe /c mklink /D "E:\NetApp\WFA\jboss\standalone\workflow-help""E:\NetApp\WFA\jboss\standalone\help.war\workflow"
