跳转到主内容
OnCommand Performance Manager 1.0 无法再监控集群
5
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
om
Last Updated:
状态信息
适用于
OnCommand Performance Manager (OCPM) 1.0
问题
OnCommand Performance Manager 报告类似以下内容的错误:
SERVER LOG: ERROR [http-443-21] OriginatorUpdateServlet (OriginatorUpdateServlet.java:63) - Failed to get update server with the xml, originator 1: com.netapp.oci.server.UpdateTaskException [1-100] Failed to get update server with the xml, originator 1 com.netapp.oci.server.UpdateTaskException [1-100] Error when process from originId:1 originName:<IP-ADDRESS> com.onaro.sanscreen.util.xml.XMLException [1-100] Fail update:
com.netapp.oci.platform.originator.OriginatorUpdateHandler@abc123
com.netapp.oci.platform.originator.OriginatorUpdateException [abc] Key-cache exception Caused by: com.netapp.oci.platform.originator.key.KeyCacheException: StorageShelf 123456 is owned by originator 2 and can't be used by originator 1
ACQUISITION LOG: 2015-05-15 08:00:00,035 FATAL [pool-2-thread-971] com.onaro.sanscreen.acquisition.framework.datasource.BaseDataSource (BaseDataSource.java:315) - [netappfoundation] <IP-ADDRESS> - Runtime exception: Cannot update server (com.netapp.oci.server.UpdateTaskException [62-290] Error when process from originId:1 originName:<IP-ADDRESS> com.onaro.sanscreen.util.xml.XMLException [62-290] Fail update: com.netapp.oci.platform.originator.OriginatorUpdateHandler@2618de79 com.netapp.oci.platform.originator.OriginatorUpdateException [290] Key-cache exception)
com.onaro.sanscreen.acquisition.framework.FrameworkException: Cannot update server (com.netapp.oci.server.UpdateTaskException [62-290] Error when process from originId:1 originName:<IP-ADDRESS> com.onaro.sanscreen.util.xml.XMLException [62-290] Fail update: com.netapp.oci.platform.originator.OriginatorUpdateHandler@123456 com.netapp.oci.platform.originator.OriginatorUpdateException [290] Key-cache exception) Caused by: java.io.IOException: Server returned HTTP response code: 500 for URL: https://localhost:443/api/originatorUpdate/NETAPP/1
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
