跳转到主内容
OnCommand Insight Dataawarehouse 7.3.10+ 无法安装 DB2
44
Visibility:
Votes:
0
Category:
oncommand-insight-data-warehouse
Specialty:
oci
Last Updated:
适用场景
  • OnCommand Insight数据仓库 7.3.10及更高版本
  • 支持的Windows操作系统
问题描述
  • 以下是 installer path\install_oci_dwh.bat 尝试安装OnCommand数据仓库 7.3.10+时在命令提示符窗口或中观察到的错误
  • ' was unexpected at this time
  • DB2安装失败并被 卸载
Creating sample Db2 database.
The system cannot find the path specified.
ERROR: Validation of Db2 installation failed.
ERROR: Encountered an error while installing Db2.
Db2 will be uninstalled in 10 seconds.
Db2 uninstall in progress.
'"e:\IBM\DB2\tempDb2Uninstall\db2unins.exe"' is not recognized as an internal or external command,
operable program or batch file.
Check "DB2-0" service exists or not, if not we can safely remove the DB2 install folder.
[SC] EnumQueryServicesStatus:OpenService FAILED 1060:
The specified service does not exist as an installed service.
Db2 uninstall completed.
New to NetApp?
