OnCommand Insight 7.x 不支持使用带有 RSSAA-电源 签名的证书的设备
适用于
OnCommand Insight (OCI) 7.x
问题
单击“再次轮询”后、数据源页面上将显示以下消息:
日志中的故障模式类似于以下内容:
Failed to execute request: java.security.cert.CertificateException: Certificates do not conform to algorithm constraints and specifically: Caused by: java.security.cert.CertPathValidatorException: Algorithm constraints check failed on signature algorithm: 1.2.840.113549.1.1.10 The string "1.2.840.113549.1.1.10" is synonymous with "RSASSA-PSS". Java versions below 13.0 do not have full support of this standard.
