管理工具(System Manager、AIQUM)受无响应Web服务的影响
适用场景
- ONTAP 9
- ONTAP System Manager
- Active IQ Unified Manager ( AIQUM )
问题解答
- ONTAP中某个节点上的Web服务出现故障或无响应可能会对某些管理工具(例如ONTAP System Manager和Active IQ Unified Manager)造成影响
- 尝试与管理LIF所在的节点建立HTTP/S连接可能会失败
- 尝试查看时
system services web show、您可能会看到状态为Partial
- 尝试查看时
cluster::> system services web show
External Web Services: true
Status: partial <--------------
HTTP Protocol Port: 80
HTTPs Protocol Port: 443
TLSv1 Enabled: true
SSLv3 Enabled: true
SSLv2 Enabled: false
cluster::> system services web node show
Node External HTTP Port HTTPs Port Status HTTP Requests Bytes Served
node-01 true 80 443 offline - -
node-02 true 80 443 online 2104 6534104
2 entries were displayed.
END
- System Manager出现以下错误
Connection has been shutdown: javax.net.ssl.SSLException:java.net.SocketException: Software caused connection abort: recv failed500 Connection refused500 Connection has been shutdown: javax.net.ssl.SSLException: java.net.SocketException: Connection reset- 有关System Manager帮助,请参阅 System Manager报告500 connection refused to f五百份web services
- Active IQ Unified Manager 出现以下错误
Cluster Not Reachable
追加信息
附加信息 _text
