跳转到主内容
NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
OCI DWH 安装在安装 Cognos 阶段失败 服务器
6
Visibility:
Votes:
0
Category:
oncommand-insight-data-warehouse
Specialty:
oci
Last Updated:
适用于
  • OnCommand Insight ( OCI )数据仓库( DWH ) 7.3.11
  • 在 Windows 操作系统上安装
问题
  • "Installing Cognos Server ..."的阶段, OCI DWH 安装失败。
示例:
  • install_oci_dwh_msi.log 显示如下示例所示的输出。
示例:
MSI (s) (E0:D8) [10:52:00:785]: Executing op: ActionStart(Name=Install_DWH_Server,Description=Installing Cognos Server ...,)
Action 10:52:00: Install_DWH_Server. Installing Cognos Server ...
MSI (s) (E0:D8) [10:52:00:785]: Executing op: CustomActionSchedule(Action=Install_DWH_Server,ActionType=9250,Source=C:\Program Files\SANscreen\,Target=**********,)
CustomAction Install_DWH_Server returned actual error code 1 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (E0:D8) [10:57:06:516]: Note: 1: 1722 2: Install_DWH_Server 3: C:\Program Files\SANscreen\ 4: **********
MSI (s) (E0:D8) [10:57:06:516]: Note: 1: 2205 2:  3: Error
MSI (s) (E0:D8) [10:57:06:516]: Note: 1: 2228 2:  3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1722
  • <Installation_Path>\SANscreen\bin\log\install.cognos.server.log 显示以下构建错误。
BUILD FAILED
C:\Program Files\SANscreen\bin\setup.xml:1190: The following error occurred while executing this line:
C:\Program Files\SANscreen\bin\setup.xml:1292: exec returned: -1
   at org.apache.tools.ant.taskdefs.ExecTask.runExecute(ExecTask.java:644)
   at org.apache.tools.ant.taskdefs.ExecTask.runExec(ExecTask.java:670)
   at org.apache.tools.ant.taskdefs.ExecTask.execute(ExecTask.java:496)
   at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:293)
   at sun.reflect.GeneratedMethodAccessor4.invoke(Unknown Source)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
New to NetApp?
Scan to view the article on your device
