跳转到主内容
Java 为 API-S 中的采集单元服务引发 HeapDumpOnOutOfMemoryError 异常
17
Visibility:
Votes:
0
Category:
oncommand-api-services-api-s
Specialty:
OM
Last Updated:
适用于
  • Linux 中的 OnCommand API 服务 2.2P1 ( API-S )
问题
  • Java 引发 HeapDumpOnOutOfMemoryError 异常
  • 大型堆转储文件在中使用 /var/log/ocie .hprof 扩展名创建 这将填满文件系统
文件的示例名称: java_pid9127.hprof
  • 执行命令 ps -aux | grep 9127 可提供以下输出:
jboss   9127   1 99 Jun16 ?     203-01:22:05 java -Djna.tmpdir=/opt/netapp/data/tmp -Djava.io.tmpdir=/opt/netapp/data/tmp -D https.protocols=TLSv1,TLSv1.1,TLSv1.2 -Dlog4j.configurationFile=ocie-production.xml
-Donaro.home=/opt/netapp/essentials -Dcodebase= https://localhost:8443 -Djava.library.path=/opt/netapp/essentials/au/bin -Dacq.home=/opt/netapp/essentials/au -Djava.security.properties=/opt/netapp/essentials/au/conf/java.security
-Djava.rmi.server.hostname=localhost -Xmx2163m -Xms256m -XX:PermSize=64m -XX:MaxPermSize=256m -classpath /opt/netapp/essentials/au/conf:/opt/netapp/essentials/au/*:/opt/netapp/essentials/au/lib/*:/opt/netapp/essentials/au/lib/xml/xerces/*:
/opt/netapp/essentials/au/lib/xml/jdom/*:/opt/netapp/essentials/au/lib/jboss/client/*:/opt/netapp/essentials/au/lib/xml-3rd/*:/opt/netapp/essentials/au/lib/shared/* -Dno.trap=false -XX:+HeapDumpOnOutOfMemoryError -XX:HeapDumpPath=/var/log/ocie
-XX:ErrorFile=/var/log/ocie/au_error_%p.log -DJDBC_DRIVER=org.mariadb.jdbc.Driver -Djava.net.preferIPv6Stack=true -Djava.net.preferIPv6Addresses=true -verbose:gc -Xloggc:/var/log/ocie/gc_au.log -XX:+PrintGCDateStamps -XX:+PrintGCDetails
-XX:+UseGCLogFileRotation -XX:NumberOfGCLogFiles=10 -XX:GCLogFileSize=5M -XX:+UseG1GC -XX:+UseStringDeduplication -XX:+PrintTenuringDistribution com.onaro.sanscreen.acquisition.framework.Main start
  • 我们发现​​​​​​ ,采集单元服务的 Xmx 值为 216 米。
New to NetApp?
