跳转到主内容
如何使用测试与 OnCommand Workflow Automation 的集群连接 "Connect-NcController" cmdlet
15
Visibility:
Votes:
0
Category:
oncommand-workflow-automation-wfa
Specialty:
om
Last Updated:
适用场景
  • OnCommand Workflow Automation 4.2
  • OnCommand Workflow Automation 5.0
  • OnCommand Workflow Automation 5.1
  • ONTAP
  • NetApp PowerShell 工具包
问题描述
本文将介绍如何使用 OnCommand Workflow Automation 附带的 "Connect-NcController" cmdlet 对 ONTAP 集群进行基本连接测试。此 cmdlet 也包含在 NetApp PowerShell 工具包中。"Connect-NcController" cmdlet 可用于对 OnCommand Workflow Automation 与 ONTAP 集群之间的连接错误进行故障排除,请参见以下示例错误。
INFO [Create qtree] Connect-NcController (with credentials) -Name cluster01 -Timeout 60000 -ErrorAction Stop -SSLVersion TLSv1
INFO [Create qtree] Connect-Controller -Type CLUSTER -Name cluster01 -Credential System.Management.Automation.PSCredential -Vserver -SSLversion TLSv1.2
INFO [Create qtree] Credentials successfully provided for 'cluster01'
INFO [Create qtree] Connect-NcController (with credentials) -Name cluster01 -Timeout 60000 -ErrorAction Stop -SSLVersion TLSv1.2
ERROR [Create qtree] Failed to connect to cluster node: cluster01.
New to NetApp?
