跳转到主内容
NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
如何更改物理接口上的流控制和 MTU 设置、并最大限度地减少生产环境中的中断
22
Visibility:
Votes:
0
Category:
oncommand-system-manager
Specialty:
cifs
Last Updated:
适用于
  • ONTAP 9
  • Data ONTAP 8.1 7-模式
  • OnCommand System Manager
  • Data ONTAP 7 及更早版本
说明
当物理接口是诸如 VIF 或 IFGRP 等逻辑接口的一部分时,不能修改 MTU 和流控制设置。因此,您必须破坏逻辑接口并使用ifconfig该命令进行更改、/etc/rc或者无中断地更改/etc/rc文件并执行接管和恢复。cf takeovercf giveback 命令可用于以无中断的方式对 HA 对中的接口组进行更改。有关详细信息,请参见对接口组进行无中断更改
更改/etc/rc文件的配置、以便可以读取文件并配置接口、以便下次反映新的 MTU 大小和流量控制设置、如下例所示。应在创建和配置逻辑接口之前修改 MTU 和 / 或 FlowControl 设置。
注:应用以下配置将导致 OnCommand System Manager ( OCSM )在单击网络接口时显示以下消息
Active operations on network interfaces are disabled because the /etc/rc file does not adhere to the format supported by System Manager. Modify the /etc/rc manually to enable the active operations.
根据 OCSM 文档中的问题 810865 ,这是预期的。 .  此后必须手动修改 /etc/rc 文件。
:在集群模式 Data ONTAP 中、对流控制或 MTU 的修改将导致特定网络端口上的服务再次中断。
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
