跳转到主内容
如何允许 OPM 添加以前由其他 OPM 实例管理的集群
482
Visibility:
Votes:
0
Category:
oncommand-system-manager
Specialty:
legacy
Last Updated:
适用于
  • OnCommand Performance Manager (OPM) 1.1、2.0、2.1、7.0、7.1。
  • OnCommand Unified Manager (OCUM) 7.3+
说明
当集群被添加为数据源时,OPM 在 ONTAP 中注册为应用程序。ONTAP 在 8.2 和 8.3 版本之间策略组行为的变化迫使 OPM 1.1 发生变化,以防止有害行为。OPM 1.1 中添加了一个限制,以防止将单个集群作为数据源添加到多个 OPM 1.1 实例中,以防止有害行为。
在非常具体的情况下,从群集中手动删除 OPM 应用程序记录可能至关重要,以允许将群集移动到新的或不同的 OPM 实例。可能会报告以下一个或多个消息:
  • You must remove cluster from the instance of OnCommand Performance Manager above before adding it to this instance of OnCommand Performance Manager.
  • Cluster is currently managed by the following instance of OnCommand Performance Manager. Managing a cluster with multiple instances of the same application will impact the performance of the cluster.
  • Cluster settings are modified successfully in Unified Manager. But cluster add failed for Performance Manager. Cluster <<CLUSTER_NAME>> is already managed by OnCommand Performance Manager with system id <<UNIQUE_UUID>> at https://<<IP_ADDRESS>>:443.
New to NetApp?
