跳转到主内容
在 OnCommand Workflow Automation 中配置 Active Directory 身份验证失败
24
Visibility:
Votes:
0
Category:
oncommand-workflow-automation-wfa
Specialty:
om
Last Updated:
适用场景
  • OnCommand Workflow Automation ( WFA ) 2.x
  • OnCommand Workflow Automation ( WFA ) 3.x
  • OnCommand Workflow Automation ( WFA ) 4.x
问题描述
使用 AD 身份验证时, GUI 中会出现以下错误之一:
  • The username or password is incorrect
  • Connection to server lost
wfa_ldap.log 在文件中显示错误示例:
  • 2017-0101 14:00:00,000 ERROR [com.netapp.wfa.ldap.LdapWrapper] (default task-6) Failed to find user in LDAP: javax.naming.NamingException: JBAS011843: Failed instantiate InitialContextFactory com.sun.jndi.ldap.LdapCtxFactory from classloader ModuleClassLoader for Module "deployment.wfa-0.5.ear.flex-server-facade-0.5.war:main" from Service Module Loader [Root exception is javax.naming.AuthenticationException: [LDAP: error code 49 - 80090308: LdapErr: DSID-0C0903C5, comment: AcceptSecurityContext error, data 52e, v2580 ]]
  • INFO [com.netapp.wfa.ldap.LdapWrapper] (http-executor-threads - 32) Search result found <user_name> ERROR [com.netapp.wfa.ldap.LdapLoginModule] (http-executor-threads - 32) null: java.lang.NullPointerException
  • ERROR [com.netapp.wfa.ldap.LdapWrapper] (default task-9) An error occurred while searching for parent group of group '<Distingished name>': javax.naming.directory. InvalidSearchFilterException: Unbalanced parenthesis; remaining name 'DC=domain,DC=com'
  • 2017-0101 14:00:00,000 WARN [com.netapp.wfa.ldap.LdapLoginModule] (default task-2) User <user_name@domain_name> couldn't be logged in using LDAP, reverting to local WFA login
New to NetApp?
