复杂密码会中断 MySQL 部件上的 WFA 5.0 分期付款
适用于
- WFA 5.0
- Windows Server 2019
问题
无法安装 WFA 5.0
安装日志:
configureMySQL : MySQL config file is : C:\Program Files\NetApp\WFA\bin\supportfiles\MySQLConfig.txt
Custom Install Log INFORMATION:
Entering function GetRegistryKeyValue with parameters RegistryPath=SOFTWARE\WOW6432Node\MySQL AB\MySQL Server 5.7 Registry key=DataLocation Type=1
RegDBGetKeyValueEx failed to getDataLocation
Failed to get:DataLocation under path:SOFTWARE\WOW6432Node\MySQL AB\MySQL Server 5.7
MySQL ini file is : my.ini
Could find the strings in file my.ini
Could find the strings sql-mode in file my.ini.
