跳转到主内容
尝试登录到 DWH 报告门户失败,并显示错误: "DPM-Gty-5003" 或 "CAM-CRP-1064 Unable to process the PKCS #7" 或 "CAM-CRP-1093 unable to read the contents of the keystore"
8
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
适用于
  • DWH 版本 7.0.x
  • DWH 版本 7.1.1
  • DWH 7.1.2 版
  • DWH 版本 7.2.0
问题
尝试登录到 DWH 报告门户失败,并在日志中显示 Invalid credentials 错误和以下错误:
-or -
CAM-CRP-1093 Unable to read the contents of the keystore
when restarting the Cognos services from IBM Cognos Configuration window , the PKCS/ Certificate key errors are reported :
[ ERROR ]
CAM-CRP-1093 Unable to read the contents of the keystore '.../Program Files/SANscreen/cognos/c10_64/configuration/csk\jCSKKeystore'. Reason: java.io.IOException: com.sun.crypto.provider.SealedObjectForKeyProtector
CAM-CRP-1064 Unable to process the PKCS #7 data because of an internal error. Unable to read the contents of the keystore '.../Program Files/SANscreen/cognos/c10_64/configuration/csk\jCSKKeystore'. Reason: java.io.IOException: com.sun.crypto.provider.SealedObjectForKeyProtector
DPR-DPR-1035 Dispatcher detected an error.</messageString></message><message><messageString>CM-CFG-5084 An error occurred while reading the startup configuration file.</messageString></message></messages>    problem starting handler ContentManagerLifecycleHandlerCM-CFG-5084 An error occurred while reading the startup configuration file. java.lang.RuntimeException: CM-CFG-5084 An error occurred while reading the startup configuration file.           at com.cognos.cm.server.ConfigurationFactory.getConfig(ConfigurationFactory.java:59)     at com.cognos.cm.server.CMServlet.<init>(CMServlet.java:224)
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
