跳转到主内容
升级到 OnCommand Workflow Automation 5.1.x 后,身份验证将通过 LDAP 不再起作用
102
Visibility:
Votes:
0
Category:
oncommand-workflow-automation-wfa
Specialty:
om
Last Updated:
状态信息
适用于
  • OnCommand Workflow Automation ( WFA ) 5.1RC1
  • OnCommand Workflow Automation ( WFA ) 5.1.1
  • Microsoft Windows Server
问题
将 OnCommand Workflow Automation 升级到版本 5.1.x 后, LDAP 身份验证失败,具体而言, LDAP 会受到影响。
  • 在 wfa_ldap.log 中出现错误
2020-03-04 09:40:34,381 ERROR [com.netapp.wfa.ldap.LdapWrapper] (default task-5) Failed to find user in LDAP: javax.naming.CommunicationException: qbitdcp001.operation.lan:636 [Root exception is java.lang.NullPointerException]...
  • wfa.log 中出现错误
2020-03-04 09:40:34,350 WARN  [com.netapp.wfa.common.ssl.SslCertificateUtils] (default task-5) Failed during SSLCertificateUtils:getKeyStore: java.io.EOFException
 at java.base/java.io.DataInputStream.readInt(DataInputStream.java:397)
 at java.base/com.sun.crypto.provider.JceKeyStore.engineLoad(JceKeyStore.java:700)
 at java.base/java.security.KeyStore.load(KeyStore.java:1479)
 at deployment.wfa-0.5.ear.common- .....
New to NetApp?
