跳转到主内容
ActiveIQ Unified Manager 用户被迫注销 UI 、集群监控失败
31
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
适用于
  在 RHEL 和 OVA 上运行 Active IQ Unified Manager 9.7(um) 。
问题
  • 用户从 Unified Manager 服务器强制注销。
  • "Storage Management">"Cluster Setup" 下的 UM Web UI 中,大多数 / 所有集群的操作状态都将显示为 "Failed"
  • 文件中将出现以下错误 au.log file
2020-03-30 18:54:56,227 ERROR [main] c.o.s.a.f.Main (Main.java:66) - Main - failed to start services: Failed to start acquisition - Failed to load certificates java.io.IOException: DerInputStream.getLength(): lengthTag=109, too big.
 at java.base/sun.security.util.DerInputStream.getLength(DerInputStream.java:606) ~[?:?]
 at java.base/sun.security.util.DerValue.init(DerValue.java:390) ~[?:?]
 at java.base/sun.security.util.DerValue.(DerValue.java:331) ~[?:?]
 at java.base/sun.security.util.DerValue.(DerValue.java:344) ~[?:?]
 at java.base/sun.security.pkcs12.PKCS12KeyStore.engineLoad(PKCS12KeyStore.java:1993) ~[?:?]
 at java.base/sun.security.util.KeyStoreDelegator.engineLoad(KeyStoreDelegator.java:222) ~[?:?]
 at java.base/java.security.KeyStore.load(KeyStore.java:1479) ~[?:?]
 at com.onaro.sanscreen.acquisition.framework.mgmt.CertificateDownloader.loadKeyStore(CertificateDownloader.java:211) ~[au-framework.jar:9.7.0-2020.03.J3229]
 at com.onaro.sanscreen.acquisition.framework.mgmt.CertificateDownloader.loadCertificates(CertificateDownloader.java:155) ~[au-framework.jar:9.7.0-2020.03.J3229]
 at com.onaro.sanscreen.acquisition.framework.mgmt.HttpBasedUrlConnection.loadCertificates(HttpBasedUrlConnection.java:146) ~[au-framework.jar:9.7.0-2020.03.J3229]
 at com.onaro.sanscreen.acquisition.framework.mgmt.HttpBasedUrlConnection.initSSL(HttpBasedUrlConnection.java:83) ~[au-framework.jar:9.7.0-2020.03.J3229]
 at com.onaro.sanscreen.acquisition.framework.mgmt.CommunicationManager.setUpConnection(CommunicationManager.java:369) ~[au-framework.jar:9.7.0-2020.03.J3229]
 at com.onaro.sanscreen.acquisition.framework.mgmt.CommunicationManager.doStart(CommunicationManager.java:136) ~[au-framework.jar:9.7.0-2020.03.J3229]
 at com.onaro.sanscreen.acquisition.framework.mgmt.FrameworkService.start(FrameworkService.java:75) ~[au-framework.jar:9.7.0-2020.03.J3229]
 at com.onaro.sanscreen.acquisition.framework.mgmt.ServiceManager.doStart(ServiceManager.java:215) ~[au-framework.jar:9.7.0-2020.03.J3229]
 ... 4 more
New to NetApp?
