跳转到主内容
购买服务器不会在运行 RHEL 7.x 或 OVA 的 OnCommand Unified Manager 9.5 上继续启动
15
Visibility:
Votes:
0
Category:
oncommand-unified-manager
Specialty:
om
Last Updated:
适用于
  • OnCommand Unified Manager 9.5
  • RHEL 7.x
  • virtual appliance
问题
从 Unified Manager 9.4 升级到 9.5 后、 "OCIEU" 服务不会保持联机状态。
OCUM/OnCommand Unified Manager 9.x 无法监控所有集群、因为购买服务已关闭。
升级 OnCommand Unified Manager 后、在 RHEL 7.x 上不能在线获取 OCIEU 服务。
检查 OCeau 服务的状态:
 systemctl status ocieau.service
* ocieau.service - LSB: OnCommand Insight Essentials AU
 Loaded: loaded (/opt/netapp/systemd/system/ocieau; enabled; vendor preset: disabled)
 Active: inactive (dead) since Mon 2019-01-21 10:39:20 CET; 23min ago
 Process: 16276 ExecStop=/opt/netapp/systemd/system/ocieau stop (code=exited, status=0/SUCCESS)
 Process: 15656 ExecStart=/opt/netapp/systemd/system/ocieau start (code=exited, status=0/SUCCESS)
 Main PID: 15656 (code=exited, status=0/SUCCESS)
Jan 21 10:37:53 %SystemName% systemd[1]: Starting LSB: OnCommand Insight Essentials AU...
Jan 21 10:37:53 %SystemName% ocieau[15656]: Starting NetApp OnCommand Insight Essentials Acqisition service ocieau
Jan 21 10:37:53 %SystemName% ocieau[15656]: NetApp OnCommand Insight Essentials Acquisition service started successfully
Jan 21 10:37:53 %SystemName% systemd[1]: Started LSB: OnCommand Insight Essentials AU.
Jan 21 10:39:20 %SystemName% systemd[1]: Stopping LSB: OnCommand Insight Essentials AU...
Jan 21 10:39:20 %SystemName% ocieau[16276]: NetApp OnCommand Insight Essentials Acquisition service already stopped
Jan 21 10:39:20 %SystemName% systemd[1]: Stopped LSB: OnCommand Insight Essentials AU.
在 ocumserver.log 中有
一个等待下一个更改日志更新的列表。
%datestamp% ERROR [oncommand] [pool-21-thread-3] [c.n.i.c.u.AcquisitionUnitStatusUtil] Unable to invoke AU EJB
java.io.IOException: Failed to retrieve RMIServer stub: javax.naming.ServiceUnavailableException [Root exception is java.rmi.ConnectException: Connection refused to host: localhost; nested exception is:
        java.net.ConnectException: Connection refused (Connection refused)]
        at javax.management.remote.rmi.RMIConnector.connect(RMIConnector.java:369)
        at javax.management.remote.JMXConnectorFactory.connect(JMXConnectorFactory.java:270)
        at com.netapp.ipc.common.util.AcquisitionUnitStatusUtil.getAcquisitionUnitStartTime(AcquisitionUnitStatusUtil.java:42)
        at com.netapp.ipc.common.util.AcquisitionUnitStatusUtil.isAcquisitionUnitRunning(AcquisitionUnitStatusUtil.java:30)
        at com.netapp.scalemonitor.service.DiskMonitorService.monitor(DiskMonitorService.java:134)
        at com.netapp.scalemonitor.ScaleMonitor.monitorDiskSpace(ScaleMonitor.java:35)
        at com.netapp.scalemonitor.ScaleMonitorConfiguration$1.run(ScaleMonitorConfiguration.java:55)
        at org.springframework.scheduling.support.DelegatingErrorHandlingRunnable.run(DelegatingErrorHandlingRunnable.java:54)
        at org.springframework.scheduling.concurrent.ReschedulingRunnable.run(ReschedulingRunnable.java:81)
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
        at java.util.concurrent.FutureTask.run(FutureTask.java:266)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
        at java.lang.Thread.run(Thread.java:748)
Caused by: javax.naming.ServiceUnavailableException: null
        at com.sun.jndi.rmi.registry.RegistryContext.lookup(RegistryContext.java:136)
        at com.sun.jndi.toolkit.url.GenericURLContext.lookup(GenericURLContext.java:205)
        at javax.naming.InitialContext.lookup(InitialContext.java:417)
        at javax.management.remote.rmi.RMIConnector.findRMIServerJNDI(RMIConnector.java:1955)
        at javax.management.remote.rmi.RMIConnector.findRMIServer(RMIConnector.java:1922)
        at javax.management.remote.rmi.RMIConnector.connect(RMIConnector.java:287)
        ... 15 common frames omitted
Caused by: java.rmi.ConnectException: Connection refused to host: localhost; nested exception is:
        at sun.rmi.transport.tcp.TCPEndpoint.newSocket(TCPEndpoint.java:619)
        at sun.rmi.transport.tcp.TCPChannel.createConnection(TCPChannel.java:216)
        at sun.rmi.transport.tcp.TCPChannel.newConnection(TCPChannel.java:202)
        at sun.rmi.server.UnicastRef.newCall(UnicastRef.java:338)
        at sun.rmi.registry.RegistryImpl_Stub.lookup(RegistryImpl_Stub.java:112)
        at com.sun.jndi.rmi.registry.RegistryContext.lookup(RegistryContext.java:132)
        ... 21 common frames omitted
Caused by: java.net.ConnectException: Connection refused (Connection refused)
        at java.net.PlainSocketImpl.socketConnect(Native Method)
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
