跳转到主内容
无法启动端口为 80 的 OnCommand 应用程序 'Address already in use error: JVM_Bind'
123
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
om
Last Updated:
适用于
当安装在 Windows 主机上时,此问题仅影响以下 OnCommand 应用程序
  • OnCommand Insight (OCI) 7.X
  • ActiveIQ Unified Manager 9.6+
  • OnCommand Workflow Automation (WFA)
问题描述
  • 应用程序无法启动
  • :> netstat -ano| findstr -i 80 的输出显示 SYSTEM(通常为 PID 4)在端口 80 上侦听。
  • 这通常是万维网发布服务
  • 部署文件都解析为 .failed
  • 在系统日志中,在级联故障开始时看到以下错误:
Services which failed to start: service jboss.undertow.listener.default: org.jboss.msc.service.StartException in service jboss.undertow.listener.default: Could not start http listener.
20XX-XX-XX 16:05:17,892 INFO [org.jboss.as.connector.subsystems.datasources] (msc service thread 1-3) JBAS010409: Unbound Datasource [Java:/onaro_pool_acq]
20XX-XX-XX 16:05:17,908 INFO [org.jboss.as.connector.deployers.jdbc] (msc service thread 1-8) JBAS010418: Stopped Driver service with driver-name = h2
20XX-XX-XX 16:05:17,908 INFO [org.jboss.messaging] (msc service thread 1-2) JBAS011605: Unbound messaging object to jndi name java:jboss/DefaultJMSConnectionFactory
20XX-XX-XX 16:05:17,908 INFO [org.jboss.as.connector.subsystems.datasources] (msc service thread 1-4) JBAS010409: Unbound Datasource [Java:/onaro_pool]
20XX-XX-XX 16:05:17,908 INFO [org.wildfly.extension.undertow] (msc service thread 1-7) JBAS017521: Undertow HTTPS listener https suspending
20XX-XX-XX 16:05:17,923 INFO [org.jboss.as.connector.deployment] (msc service thread 1-1) : Unbound JCA ConnectionFactory [java:/JmsXA]
20XX-XX-XX 16:05:17,923 INFO [org.jboss.as.connector.messaging] (ServerService Thread Pool -- 67) JBAS011605:  Unbound messaging object to jndi name java:/queue/SummaryQueue
  • 尝试通过 WebUI 或 Java 客户端启动 OnCommand Insight 时。Java 客户端返回以下应用程序错误:  Unable to launch the application.
  • 在 jboss 日志中,报告以下错误:
ERROR [org.apache.coyote.http11.Http11Protocol] Error initializing endpoint: java.net.BindException: Address already in use: JVM_Bind /0.0.0.0:80
  • jboss/server.log 报告错误:
ERROR [org.jboss.msc.service.fail] (MSC service thread 1-7) MSC000001: Failed to start service org.wildfly.undertow.listener.default: org.jboss.msc.service.StartException in service org.wildfly.undertow.listener.default:Address already in use: bind /0.0.0.0:80
ERROR [org.jboss.as.controller.management-operation] (Controller Boot Thread) WFLYCTL0013: Operation ("add") failed - address: ([
("subsystem" =>"undertow"),
("server" =>"default-server"),
("http-listener" =>"default")
]) - failure description: {"WFLYCTL0080: Failed services" => {"org.wildfly.undertow.listener.default" =>"Address already in use: bind /0:0:0:0:0:0:0:0:80"}}
("subsystem" =>"messaging-activemq"),
("server" =>"default")
"WFLYCTL0412: Required services that are not installed:" => ["jboss.http-upgrade-registry.default"],
"WFLYCTL0180: Services with missing/unavailable dependencies" => ["jboss.messaging-activemq.default is missing [jboss.http-upgrade-registry.default]"]
  • WebUI 显示错误:
404 - Not Found
New to NetApp?
