跳转到主内容
OnCommand Insight HDS 数据源中的某些存储系统将停止 报告性能统计信息
8
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
适用场景
OnCommand Insight 7.3.X ( OCI )
问题描述
  • 对于连接到 HiCommand Device Manager 数据源的存储系统,有些系统报告性能统计信息,有些则不报告
  • OCI 中的数据源未显示任何错误
  • 用于报告性能统计信息的 API 将返回一个空集,可通过以下步骤进行确认:
    1. 从数据源下载并提取错误报告
    2. 使用存储性能报告打开一个编号的文件夹: ErrorReportName\acq\storageperformance_<datasourcename>_656_2021_02_24_11_01_32_742\1614163099532
    3. 打开recording_storageperformance-<datasourcename>.dat,然后搜索缺少的存储 统计信息
    4. 此请求将具有存储名称,响应将返回统计名称和变量类型的列表,但不会返回实际的统计数字
缺少统计信息示例请求和响应:
<<< REQUEST >>>
GET http://<tuningManagerHostnameOrIP>:22015/TuningManager/v1/objects/RAID_PI_PRCS?hostName=<dataSourceName>&agentInstanceName=<storageName>&startTime=2021-02-24T10%3A35Z&endTime=2021-02-24T10%3A39Z HTTP/1.1
<<< REQUESTEND >>>
<<< RESPONSE >>>
HTTP/1.1 200 OK
Date: Wed, 24 Feb 2021 10:39:26 GMT
Server: Cosminexus HTTP Server
X-Frame-Options: SAMEORIGIN
Cache-Control: no-store, no-cache
X-Content-Type-Options: nosniff
Content-Security-Policy: frame-ancestors 'self'
Vary: Accept-Encoding
Last-Modified: Wed, 24 Feb 2021 10:39:26 GMT
X-XSS-Protection: 1; mode=block
Keep-Alive: timeout=5, max=21
Connection: Keep-Alive
Transfer-Encoding: chunked
Content-Type: text/csv;charset=utf-8
INPUT_RECORD_TYPE,DATETIME,GMT_ADJUST,RECORD_TIME,ADAPTOR_ID,PROCESSOR_ID,INTERVAL,CONTROLLER,PROCESSOR_TYPE,PROCESSOR_BUSY_RATE,MAX_PROCESSOR_BUSY_RATE,MAX_BUFFER_LENGTH,BUFFER_IO_COUNT,MAX_BUFFER_IO_COUNT,BUFFER_IO_RATE,MAX_BUFFER_IO_RATE
string(8),time_t,long,time_t,string(16),string(16),ulong,string(8),string(8),float,float,float,float,float,float,float
<<< RESPONSEEND >>>
正在收集统计信息响应示例(已截断):
<<< RESPONSE >>>
HTTP/1.1 200 OK
INPUT_RECORD_TYPE,DATETIME,GMT_ADJUST,RECORD_TIME,LDEV_COUNT,MONITORED_LDEV_COUNT,INTERVAL,READ_IO_COUNT,READ_IO_RATE,READ_HIT_IO_COUNT,READ_HIT_RATE,WRITE_IO_COUNT,WRITE_IO_RATE,WRITE_HIT_IO_COUNT,WRITE_HIT_RATE,READ_MBYTES,READ_XFER_RATE,WRITE_MBYTES,WRITE_XFER_RATE,READ_TOTAL_RESPONSE,READ_RESPONSE_RATE,WRITE_TOTAL_RESPONSE,WRITE_RESPONSE_RATE
string(8),time_t,long,time_t,ulong,ulong,ulong,double,double,double,double,double,double,double,double,double,double,double,double,double,double,double,double
"LDA",2021-02-24 10:35:00,0,2021-02-24 10:35:01,14,14,60,4.30000000000000E+01,7.16666666666667E-01,4.30000000000000E+01,1.00000000000000E+02,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,1.00000000000000E+00,1.66666666666667E-02,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00
"LDA",2021-02-24 10:36:00,0,2021-02-24 10:36:00,14,14,59,4.30000000000000E+01,7.28813559322034E-01,4.30000000000000E+01,1.00000000000000E+02,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,1.00000000000000E+00,1.69491525423729E-02,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00
"LDA",2021-02-24 10:37:00,0,2021-02-24 10:37:00,14,14,60,4.30000000000000E+01,7.16666666666667E-01,4.30000000000000E+01,1.00000000000000E+02,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,1.00000000000000E+00,1.66666666666667E-02,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00
"LDA",2021-02-24 10:38:00,0,2021-02-24 10:38:01,14,14,61,4.50000000000000E+01,7.37704918032787E-01,4.50000000000000E+01,1.00000000000000E+02,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,1.00000000000000E+00,1.63934426229508E-02,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00
"LDA",2021-02-24 10:39:00,0,2021-02-24 10:39:00,14,14,59,4.30000000000000E+01,7.28813559322034E-01,4.30000000000000E+01,1.00000000000000E+02,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,1.00000000000000E+00,1.69491525423729E-02,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00,0.00000000000000E+00
<<< RESPONSEEND >>>
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
