跳转到主内容
Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
SCO 无法配置 Oracle 数据库设置 XML 文档( 1 , 57 )
13
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用于
适用于 Oracle 的 SnapCenter 插件( SCO )
问题
添加 Linux 主机时Failed – Configure oracle database settings: There is an error in the XML document (1, 57) ,收到数据库配置设置的错误
SMCoreService.log
 ERROR SMCore PID=[5276] TID=[53] Exception in method: InvokeXML. System.InvalidOperationException: There is an error in XML document (1, 57). ---> System.InvalidOperationException: <SmResponse xmlns=''> was not expected.
spl-log.txt
 WARN DRes-PROD c.n.c.p.u.OperatingSystemImpl - PLAT-00020: Unable to load native process library. Error: no com_netapp_common_platform_unix_FileSystemNativeImpl in java.library.path java.lang.UnsatisfiedLinkError: no com_netapp_common_platform_unix_FileSystemNativeImpl in java.library.path
New to NetApp?
Scan to view the article on your device
