跳转到主内容
密码更新后,Cognos 计划报告失败:CM-REQ-4159 CM-CAM-4005 无法进行身份验证
284
Visibility:
Votes:
0
Category:
oncommand-insight-data-warehouse
Specialty:
oci
Last Updated:
适用场景
  • OnCommand Insight (OCI) 7.3.x
  • 数据基础架构洞察力(DII)
  • IBM Cognos
问题描述
  • 更改密码后成功登录 IBM Cognos Connection,之前计划的报表将失败,但其他非计划报表在此会话期间将成功运行。
  • 计划报表失败时将出现以下错误消息:
CM-REQ-4159 Content Manager returned an error in the response header. The error "cmAuthenticateFailed CM-CAM-4005 Unable to authenticate. Check your security directory server connection and confirm the credentials entered at login" can be found in the response SOAP header. CM-REQ-4342 An error has occurred with the client.
CM-REQ-4159 Content Manager returned an error in the response header. The error "cmAuthenticateFailed CM-CAM-4005 Unable to authenticate. Check your security directory server connection and confirm the credentials entered at login." can be found in the response SOAP header. CAF-WRN-2082 An error has occurred. Please contact your administrator. The complete error has been logged by CAF with SecureErrorID:2025-05-30-20:00:00.499-#39 CM-REQ-4342 An error occurred with the client.
New to NetApp?
