在System Manager ONTAP 升级期间、脚本执行和错误初始化失败
适用场景
- ANDU (自动无中断升级)
- ONTAP 9
- System Manager
问题描述
从System Manager启动ONTAP 升级时、验证失败。可以从ONTAP 命令行界面(Command Line Interface、命令行界面)中查看这些错误和状态:
Cluster::> cluster image show-update-progress -instance
Upgrade Stage: Upgrade from <current ONTAP verison> to <target ONTAP version>
Update Phase: validation
Phase Status: paused-on-error
Phase Duration:
Phase Comments: 0 of 4 validated. Error: Internal error. Initialization failed, Action: Verify that all nodes are healthy using the "cluster show" command, then try the command again.
Elapsed duration of the phase: <time>
Estimated duration of the phase: <time>
Phase Description: Pre-update checks
Subsystem Name: ScriptExecution
Subsystem Status: Error
Subsystem Details: Error: Internal error. Initialization failed
Subsystem Action: Action: Verify that all nodes are healthy using the "cluster show" command, then try the command again
Status: Paused - An error occurred in "Pre-update checks" phase. The update cannot continue until the error has been resolved. Resolve all issues, then use the "cluster image resume-update" command to resume the update.
