跳转到主内容
Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
无法将集群添加到Active IQ Unified Manager 解析指南
13
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
适用场景
  • OnCommand Unified Manager ( OCUM )
  • Active IQ Unified Manager ( AIQUM )
  • ONTAP 9.x
问题描述
  • 将集群添加到Active IQ Unified Manager 时、Web界面可能会出现以下错误。
    • Host <IP/hostname/FQDN> you specified has identified itself with a self signed certificate for Active IQ Unified Manager that has expired. Therefore, you cannot proceed.
    • <IP/hostname/FQDN> is running an unsupported Data ONTAP version. The minimum supported version is Data ONTAP X.X.X.
    • Unable to add data source, which can be caused by reaching the max number of EMS notification destinations in the data source.
    • Cluster add failed. Cluster <IP/hostname/FQDN> already exists.
    • Invalid login credentials
    • Failed to fetch the HTTPS certificate from xxx.xxx.xxx.xxx. Enter a valid Host name or Port.
    • Failed to fetch the HTTPS certificate from hostname. Enter a valid Host name or Port.
    • Failed to fetch the HTTPS certificate from hostname.prod.org. Enter a valid Host name or Port.
  • 下面列出了每个问题的已知问题和解决方案
New to NetApp?
Scan to view the article on your device
