跳转到主内容
由于元数据不匹配, SAML 身份验证被拒绝
7
Visibility:
Customer
Votes:
0
Category:
ontap-system-manager
Specialty:
om
Last Updated:
适用场景
  • System Manager 9.7
  • Microsoft ADFS
问题描述
  • 无法通过SAML向System Manager进行身份验证、因为Idp元数据不包含电子邮件地址
  •  /mroot/etc/shibboleth/shibd.log 包含以下错误:
[kern_shibd:info:9583] ERROR OpenSAML.MetadataProvider.XML : metadata instance failed manual validation checking: EmailAddress must have TextContent
[kern_shibd:info:9583] WARN Shibboleth.SessionInitiator.SAML2 [1] [default]: unable to locate metadata for provider (https://sts.iconplc.com/adfs/services/trust)
Unknown or Unusable Identity Provider The identity provider supplying your login credentials is not authorized for use with this service or does not support the necessary capabilities
New to NetApp?
