如何验证ONTAP 与适用于Linux/OVA平台的UM之间的网络连接?
适用场景
- ActiveIQ Unified Manager (UM) 9.6及更高版本
- OnCommand 统一管理器(UM)9.5及更低版本
- ONTAP
- Linux/OVA
问题描述
- 本文介绍了检查ONTAP 与UM (Linux/OVA)之间网络连接的各种方法、用于对集群添加/采集问题进行故障排除
- 可能的UI错误:
Failed to fetch the HTTPS certificate from xxx.xxx.xxx.xxx. Enter a valid Host name or Port.
hostname or IP> cannot be contacted. Enter a valid host name or cluster management IP address, protocol and port.
Cluster cannot be reached. Ensure that there is network connectivity to the cluster and the API has not timed out
