跳转到主内容
弹性搜索索引失败会在 OnCommand Insight 中导致性能问题
14
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
适用于
  • OnCommand Insight (OCI) 7.x
问题
以下列出了与在弹性搜索中索引失败相关的问题。这些信息可以一起或单独查看。
  • 缓慢的 WebUI 搜索
  • OCI 服务器上的高 CPU 使用率
  • OCI 服务器上的高内存使用率
  • OCI 服务器上的文件系统接近已满 / 已满
  • 尝试访问 WebUI 时出现“ 404 Page Not Found ( 404 页未找到)”错误信息
  • 数据源出现故障、出现错误 " Internal error: Cannot update server (Server returned HTTP response code: 500 for URL"
server_indexer.log (位于\SANscreen\wildfly\standalone\log)中,您可能会看到与以下内容类似的失败索引讯息:
2018-01-15 20:35:00,436 ERROR [EJB default - 7] QueryIndexBuilder (QueryIndexBuilder.java:195) - Error indexing InternalVolume
 com.netapp.oci.es.ElasticsearchException: [bulkIndexById][INDEX_NAME:oci-inventory-internalvolume-2018-01-15-20-33] [ANOMALY_INDEX_TYPE: internalvolume] [IDS: [7864440,
 Caused by: com.netapp.oci.es.ElasticsearchException: Error bulk indexing data. failure in bulk
execution:
 [19439]: index [oci-inventory-internalvolume-2018-01-23-07-56], type [internalvolume], id [11609
24], message [java.lang.IllegalArgumentException: Document contains at least one immense term
in field="annotationValues.text.Automounter Path" (whose UTF8 encoding is longer than the max l
ength 32766), all of which were skipped. Please correct the analyzer to not produce such terms. T
he prefix of the first immense term is: '[47, 105, 99, 101, 110, 103, 47, 100, 102, 109, 47, 114, 103,
98, 44, 32, 47, 105, 99, 101, 110, 103, 47, 100, 102, 109, 47, 98, 108, 97]...', original message: by
tes can be at most 32766 in length; got 37802]
server.log (位于\SANscreen\wildfly\standalone\log中)中,您可能会看到类似以下内容的失败消息:
2019-06-18 07:11:26,296 ERROR [default task-33057] OriginatorWorkingSet(OriginatorWorkingSet.java:488) - <datasource> failed on submit, due to: Errors encountered while executing delete extendedData documents. failure in bulk execution:
[0]: index [oci-extended-data-v2], type [_doc], id [1871197], message [ClusterBlockException[blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];]]
[1]: index [oci-extended-data-v2], type [_doc], id [3310508], message [ClusterBlockException[blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];]]
[2]: index [oci-extended-data-v2], type [_doc], id [1567170], message [ClusterBlockException[blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];]]
[3]: index [oci-extended-data-v2], type [_doc], id [4478203], message [ClusterBlockException[blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];]]
[4]: index [oci-extended-data-v2], type [_doc], id [4311330], message [ClusterBlockException[blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];]]
oci - cluster.log (位于\SANscreen\program_data\elasticsearch\logs中)中,您可能会看到类似以下内容的失败消息:
[2018-03-26T17:55:13,054][WARN ][o.e.c.a.s.ShardStateAction] [<datasource>] [oci-timeseries-qtree-2018-03-11][1] received shard failed for shard id [[oci-timeseries-qtree-2018-03-11][1]], allocation id [sSKYeTqNR46jrWY-rGw1XA], primary term [0], message [failed recovery], failure [RecoveryFailedException[[oci-timeseries-qtree-2018-03-11][1]: Recovery failed on {XXXXXXXX}{6HO5LMOIRYCEAWKINLSCIQ {TB2VITKTREOZQLBQLXWMIG}{127.0.0.1}{127.0.0.1:9310}]; nested: IndexShardRecoveryException[failed recovery]; nested: IllegalStateException[pre-1.4 translog found [F:\NetApp\SANscreen\program_data\elasticsearch\data\nodes\0\indices\KeESoUKHROaLhn6_WseZVQ\1\translog\translog-1.tlog]]; ] org.elasticsearch.indices.recovery.RecoveryFailedException: [oci-timeseries-qtree-2018-03-11][1]: Recovery failed on {XXXXXXXX}{6HO5LMOIRYCEAWKINLSCIQ}{TB2VITKTREOZQLBQLXWMIG}{127.0.0.1}{127.0.0.1:9310}
Caused by: org.elasticsearch.index.shard.IndexShardRecoveryException: failed recovery
 at org.elasticsearch.index.shard.StoreRecovery.executeRecovery(StoreRecovery.java:299) ~[elasticsearch-5.4.2.jar:5.4.2]
 at org.elasticsearch.index.shard.StoreRecovery.recoverFromStore(StoreRecovery.java:88) ~[elasticsearch-5.4.2.jar:5.4.2]
 at org.elasticsearch.index.shard.IndexShard.recoverFromStore(IndexShard.java:1238) ~[elasticsearch-5.4.2.jar:5.4.2]
 at org.elasticsearch.index.shard.IndexShard.lambda$startRecovery$1(IndexShard.java:1486) ~[elasticsearch-5.4.2.jar:5.4.2]
 ... 4 more
Caused by: java.lang.IllegalStateException: pre-1.4 translog found [F:\NetApp\SANscreen\program_data\elasticsearch\data\nodes\0\indices\KeESoUKHROaLhn6_WseZVQ\1\translog\translog-1.tlog]
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
