跳转到主内容
Active IQ Unified Manager 界面不会显示任何事件
1
Visibility:
Votes:
0
Category:
oncommand-unified-manager
Specialty:
om
Last Updated:
适用场景
Active IQ Unified Manager ( UM )
问题描述
  • 用户可以登录到 Web 界面,但不会加载页面的对象数据
  • 所有部署文件均已部署
  • MySQL 错误日志中会显示此类型的错误:
2020-05-15T15:53:43.132646Z 18 [Warning] InnoDB: Difficult to find free blocks in the buffer pool (75980 search iterations)! 75980 failed attempts to flush a page! Consider increasing the buffer pool size. It is also possible that in your Unix version fsync is very slow, or completely frozen inside the OS kernel. Then upgrading to a newer version of your operating system may help. Look at the number of fsyncs in diagnostic info below. Pending flushes (fsync) log: 0; buffer pool: 0. 244072 OS file reads, 20565 OS file writes, 783 OS fsyncs. Starting InnoDB Monitor to print further diagnostics to the standard output.
  • my.cnf此文件具有以下值:
innodb_buffer_pool_size=0M
New to NetApp?
Scan to view the article on your device
