Active IQ Unified Manager 无法添加 ONTAP 集群,因为 EMS 通知目标的最大数量被违反
适用场景
- Active IQ Unified Manager 9.x
- ONTAP 9.
问题描述
- 尝试 从"Cluster Setup" 页面在Active IQ Unified Manager中添加ONTAP集群数据源 失败。
- 提示返回 错误消息:
Unable to add data source, which can be caused by reaching the max number of EMS notification destinations in the data source.
或
Unable to add cluster data source. This can occur if the clocks on the systems are not synchronized and the Active IQ Unified Manager HTTPS certificate start date is later than the date on the cluster, or if the cluster has reached the maximum number of EMS notification destinations.
