由于桥接器发现而导致 Unified Manager MCC 监控失败
适用于
- Active IQ Unified Manager 9.7%
- 延伸型 MCC 系统
问题
一个或多个 MCC 集群持续发生故障、监控状态保持为“故障”
中出现错误 ocumserver.log
2020-04-07 08:16:17,963 ERROR [oncommand] [reconcile-3] [trtnas02mp(incremental@08:16:15.965)] [c.n.dfm.collector.OcieJmsListener] Inventory change listener error
com.netapp.dfm.ontap.outbound.zapi.OcumMonitoringFailedException: could not execute batch
Caused by: org.hibernate.exception.ConstraintViolationException: could not execute batch...
Caused by: java.sql.BatchUpdateException: (conn=673) Duplicate entry '16069-2131000011' for key 'nodebridgeconnection.NodeBridgeConnection_NodeId_BridgeId_UQ'...
Caused by: java.sql.SQLIntegrityConstraintViolationException: (conn=673) Duplicate entry '16069-2131000011' for key 'nodebridgeconnection.NodeBridgeConnection_NodeId_BridgeId_UQ'
Caused by: java.sql.SQLException: Duplicate entry '16069-2131000011' for key 'nodebridgeconnection.NodeBridgeConnection_NodeId_BridgeId_UQ'
Followed by
org.springframework.dao.DataIntegrityViolationException: could not execute batch; SQL [insert into NodeBridgeConnection (resourceKey, objVersion, objectName, healthStatus, bridge_id, cluster_id, node_id, id) values (?, ?, ?, ?, ?, ?, ?, ?)]; constraint [nodebridgeconnection.PRIMARY]; nested exception is org.hibernate.exception.ConstraintViolationException: could not execute batch
注:Unified Manager 日志文件位置
