跳转到主内容
Kubernetes Pod 上的 Trident Pod 未正确终止
25
Visibility:
Votes:
0
Category:
trident-kubernetes
Specialty:
snapx
Last Updated:
适用于
适用于 Kubernetes/OpenShift 的 Trident
问题
下面列出了与 Trident 相关的 Pod :
NAME                          READY   STATUS        RESTARTS AGE   IP            NODE              NOMINATED NODE  READINESS GATES
trident-csi-4cbtt             2/2     Running       4        96d  <MASTER_IP_1> caas-master01-01 <none>         <none>
trident-csi-5b59f59cc8-9wqp5  5/5     Running       0        11h  <NODE_IP_11>  caas-node01-01   <none>         <none>
trident-csi-5b59f59cc8-m9tdz  5/5     Terminating   0        12h  <NODE_IP_22>  caas-node02-02   <none>         <none>
trident-csi-dl972             2/2     Running       6        96d  <NODE_IP_22>  caas-node03-03   <none>         <none>
trident-csi-h25g4             2/2     Running       6        96d  <MASTER_IP_1> caas-master03-03 <none>         <none>
trident-csi-nzzgj             2/2     Running       4        96d  <MASTER_IP_1> caas-master02-02 <none>         <none>
虽然新的 Trident 配置 Pod 出现错误,但出现以下错误:
time="2020-11-30T23:55:58Z" level=error msg="Trident REST interface was not available after 30.00 seconds."
time="2020-11-30T23:55:58Z" level=debug msg="Updating Trident Provisioner CR after failed installation." name=trident
namespace=trident time="2020-11-30T23:55:58Z" level=info msg="'TridentProvisioner' CR updated." name=trident namespace=trident
time="2020-11-30T23:55:58Z" level=error msg="error syncing 'trident/trident': reconcile failed; error re-installing Trident 'trident' in namespace 'trident'; err: reconcile failed;
  unable to upgrade connection: Authorization error (user=kube-apiserver-kubelet-client, verb=create, resource=nodes, subresource=proxy);
  use 'tridentctl logs' to learn more, requeuing"
New to NetApp?
