由于通信错误、向Trident CSI控制器注册节点失败
适用场景
Astra Trident
问题描述
- Trident CSI无法将其节点注册到Trident CSI控制器、并显示以下消息:
level=warning msg="Could not update Trident controller with node registration, will retry." error="could not log into the Trident CSI Controller: error communicating with Trident CSI Controller; Put \"https://<TRIDENT_CSI>:34571/trident/v1/node/<WORKER_NODE>": dial tcp <TRIDENT_CSI>:34571: connect: connection refused" increment=10.34424336s requestID=<UUID> requestSource=Internal
- 包含的Trident驱动程序注册器日志会在连接到UNIX套接字时返回错误:
W0814 02:11:11.445999 22234 connection.go:173] Still connecting to unix:///plugin/csi.sock W0814 02:11:21.446191 22234 connection.go:173] Still connecting to unix:///plugin/csi.sock W0814 02:11:31.446114 22234 connection.go:173] Still connecting to unix:///plugin/csi.sock W0814 02:11:41.446161 22234 connection.go:173] Still connecting to unix:///plugin/csi.sock W0814 02:11:51.445607 22234 connection.go:173] Still connecting to unix:///plugin/csi.sock W0814 02:12:01.445543 22234 connection.go:173] Still connecting to unix:///plugin/csi.sock W0814 02:12:11.445383 22234 connection.go:173] Still connecting to unix:///plugin/csi.sock W0814 02:12:21.445937 22234 connection.go:173] Still connecting to unix:///plugin/csi.sock W0814 02:12:31.445422 22234 connection.go:173] Still connecting to unix:///plugin/csi.sock W0814 02:12:41.445792 22234 connection.go:173] Still connecting to unix:///plugin/csi.sock W0814 02:12:51.445988 22234 connection.go:173] Still connecting to unix:///plugin/csi.sock
- Trident CSI控制器可访问其他客户端的REST API调用
